Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
Flickering on the dash
Old Nov 30, 2023 | 12:51 PM
Cordovaii@me.com's Avatar
3rd Gear
Default Flickering on the dash and center display
Recently purchased a 2019 RR LWB Autobiography. Turned it on day two and the dash started ti flicker between selections. Almost like the button was pressed down on the steering wheel and not disengaging. It was complaining about Forward alert and Blind spot not available. As well, not able to select a terrain. Also, not forgetting when I select the A button on the screen. It flickers amber. Has anyone encountered this?
Showing Forward alert not being available
File Type: mov
Last edited by Cordovaii@me.com; Nov 30, 2023 at 12:56 PM. Reason: Adding additional area
Old Dec 2, 2023 | 05:35 AM
wcc18999's Avatar
I would take the car to the dealer to have them check your dash and power steering issue. You should probably check out the condition of your battery. With your car being a 2019, it is likely that it still has the original battery. A weak battery in these cars can cause a lot of issues. Keep us posted on your findings and good luck.
SAROVER92
Range Rover Classic (1st Gen)
Nov 24, 2023 04:49 PM
Defenderphil
May 9, 2022 09:18 AM
wrightb8289
Jun 15, 2021 03:10 PM
Bravhefen
Mar 5, 2012 05:35 PM
cst756
Mar 23, 2008 08:48 PM
