Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
New Guy- South Africa.
Old Nov 18, 2019 | 08:06 AM
Gerry SA.'s Avatar
3rd Gear
Default New Guy- South Africa.
Gerry here,
Have used the sites for years as a visitor- Great Forum. Has helped tremendously . Decided to actually join - before I send the car in I thought making use of the expertise on this forum is the first step.
2013 - L405 - Supercharged.
Radio/Sat Nav/Bluetooth/.Screen .
I was in the UK for three weeks - I had my son Start the car every few days - when he picked me up on Saturday in the car - everything was fine- later that night i went out and the radio would not work - actually the CD - Says loading CD- shows track number then changes from track 1 to 18 constantly . Sat Nav - Initializing- does not get further . Blue tooth - Please connect phone . It randomly connects the phone (Its a Landrover explore phone) then disconnects - the screen also resets on/off - initial thoughts ....bad connection. Tested all fuses connected to the screen infotainment all ok
All other functions on touch screen work - All the cameras work - the "extras tab" all functions work . Years ago on my L322 - a similar thing happened and i traced the fault to the blue tooth unit which I fixed courtesy of YOU TUBE and a Bic Plastic pen.
I did a battery test - 12 v . When running 14.6 proving the alternator works - Did hard reset - it actually fixed it for 3 minutes - then reverted to as above - Load tested the battery - "weak" Had battery tested professionally . Dead cell - Great news - At this point i was happy - Knowing that these cars dislike low-ish power - thinking this would now solve my issue - I replaced the battery - NO CHANGE.
So guys any Ideas.?
Gerry
Ian Mitchell
May 31, 2019 12:59 PM
Friday Night Disco
May 26, 2019 08:54 PM
y2motoskier
Apr 28, 2012 02:45 PM
y2motoskier
Apr 28, 2012 02:31 PM
