Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
Permanent Disable of Inteligent Start/Stop
Old Aug 27, 2023 | 12:17 PM
NewRover08's Avatar
Default Permanent Disable of Inteligent Start/Stop
Hello! Does anyone know which exact plug to disconnect to permanently disable the start/stop on a 2020 RR P400?
Thank you very much!
Old Oct 20, 2023 | 09:25 AM
GarrettSD's Avatar
I can do this via coding. I'm in San Diego though
Old Jan 7, 2026 | 12:38 PM
vogelbaugh's Avatar
8th Gear
ours was programmed when we bought it used, and the programming was wiped when i changed the battery. i am just waiting for the starter to go our because of the constant stop and start. i know you can code it, i just cant find anybody here in AZ who will do it for less than 300$
Old Jan 17, 2026 | 04:26 PM
jwest's Avatar
For anyone finding this old thread, there is no need for a "permanent" disabling because you can simply assign the CCF to just stay as it was left during previous operation. Meaning, engage the button to turn the stop/start off, and the next time you come back to start the engine, it will still be like that, off.
We use the GAP iidtool to do this. It works on my RR as well as on new Defenders.
There is a long thread on here in the 2020 defender section about GAP tool codes and things to customize.
Old Mar 30, 2026 | 01:45 PM
localbrew's Avatar
Can you do this coding with Autel?
efeblesp
Range Rover Velar
Jan 23, 2024 06:09 AM
ToiletDuck
May 21, 2022 08:50 PM
eng1tx
Jan 28, 2021 02:27 PM
eng1tx
Oct 18, 2020 02:30 PM
muffster
Jul 9, 2009 11:56 AM
