Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
Range Rover Supercharhed Suspension issue
Old Aug 19, 2023 | 10:39 PM
JerseyMed's Avatar
Default Range Rover Supercharhed Suspension issue
Hi All,
I have a 2015 Range Rover Supercharged.
I got 2 lights that came on
1) suspension fault - vehicle lean when cornering
2) suspension fault stop safely stop engine.
this is what the dealer told me that’s wrong C1119-09 HYDRAULIC PRESSURE
COMPONENT FAILURES, C104A-94 FRONT AXLE PISTON PRESSURE REGULATING VALVE, C104C-94 REAR AXLE PISTON PRESSURE REGULATING VALVE, FOUND BOTH SWAY BARS HAVE HYPER EXTENDED DUE TO INTERNAL FAILURE.
I spoke with a few people, and they told me I don’t need to replace everything they said, does anyone know what might be the issue? What’s the cheapest way to resolve this?
thanks
Stan
Old Aug 21, 2023 | 06:05 AM
wcc18999's Avatar
I am just wondering why the people you talked to recommended you not replace everything the dealership diagnosed. These are complicated vehicles, and if you do not trust what the dealership advised you, take it to a different dealership or an independent shop to get a second opinion. On the plus side, you get the assurance that a LR dealership will use OEM parts and provide a warranty on their labor and the parts they replace. Good luck to you.
Bizer
May 18, 2021 12:38 AM
Aaron York
Dec 31, 2019 11:47 AM
user 63827
Range Rover L322 (3rd Gen)
Jan 7, 2019 05:21 PM
RR85
Oct 23, 2009 10:28 AM
skinnyrunt23
Mar 31, 2005 10:42 AM
