Range Rover L460 (Fifth Gen) Talk about the Land Rover Range Rover 460 within.
2023 P530 suspension knock
Old Oct 10, 2024 | 10:09 AM
2010RRSC's Avatar
Default 2023 P530 suspension knock
I have a 2023 RR P530 with 23’s with roughly 19k miles on it. I have recently noticed which sounds like a typical bad control arm noise when traveling over speed bumps or pulling into my concrete driveway. It seems to be worse on the driver side. I have mentioned this to my dealership several times and met with the typical response of, “this is normal”. I am curious if anyone has experienced any similar noise?
Old Oct 10, 2024 | 03:06 PM
wcc18999's Avatar
I would take the tech at the dealership for a drive to let him hear the knock you are experiencing. I would also take another similar Range Rover on a test drive to confirm if this is indeed a normal noise. If the control arm is bad, it would be easy to see the defect. If your dealer is not being responsive, take it to another dealer or call Land Rover customer care. Good luck and let us know what you find out.
CantComplain
Oct 10, 2024 02:26 PM
adalton
Jul 7, 2022 05:20 PM
busrider
Aug 1, 2010 04:34 PM
ryanD2
Dec 14, 2008 08:08 PM
massrrsport06
Nov 5, 2008 09:42 PM
