Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
having a lot of issues with my p38
Old May 4, 2019 | 09:32 AM
RoverP38's Avatar
Default having a lot of issues with my p38
I travel a lot with my 1996 p38. 3 Months ago I was on the interstate and the muffler under the cab blew out. I had a shop put pipe in it’s place for the time being. It progressively started running worst. I thought the cats were stopped up, so I slit the exhaust pipe just before the cat to relieve heat if they were stopped up it would have made a difference in the run-ability I assumed. Nothing happened. So I kept driving. It starts up fine. The idle is high on initial start up but evens out as it warms up. When I put it in gear it still doesnt miss a beat. When I push the accelerator to go forward it will do fine up until about 15mph and about 1500-2000 rpms it starts to cut out and shake the whole truck and backfire. If I let off the accelerator it will smooth out until it reaches those rpms again. It will eventually gain enough speed but be jerking and sputtering and backfiring. It will not accelerate above 55mph no matter what. If I try to give it gas past 55mph it suffocates itself it seems like. The motor will stop making noise completely until I let off the gas. Please help me solve this problem. I can answer any questions if the thread is a bit confusing
Old May 4, 2019 | 10:32 AM
Dave03S's Avatar
Did you check the other muffler? Could be clogged with debris from the first muffler. Sounds a lot like clogged exhaust symptoms.
Old May 7, 2019 | 05:22 PM
Fastercat's Avatar
Is there a check engine light? Did you weld the slits back up before the cats or are they still open?
ocarlo
Sep 25, 2020 02:44 AM
Luckyjayb
Jan 24, 2017 09:06 AM
DiscoIIBrandon
Feb 8, 2011 07:44 PM
Phototone
Apr 16, 2008 11:36 AM
bobrown
Mar 17, 2006 12:24 AM
