Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
O2 Sensor Problem
Old Jun 8, 2023 | 12:49 PM
ox12345's Avatar
4wd High
Default O2 Sensor Problem
Have a USA Gasoline 2002 P38 with Bosch Engine. Check Engine light came on and codes indicated 3 o2 sensors needed replacement. I replaced all 4 but downstream Bank 1 failure came back with Check Engine light. Replaced the new one with another new one and same failure and Check engine light came back. Took it to a local shop and they said there was nothing for them to do and they thought the wires for that sensor must be broken.
I thought the plastic connectors could be problem so I cut them off and crimped wires together. Still have same problem with the failure of sensor downstream Bank 1 and check engine light.
Any ideas on what to do next? Can I rewire to the BCM or ECM? Does anyone know how?
Old Jun 8, 2023 | 03:25 PM
darrenwebb@protonmail.com's Avatar
The sensor that continues to trigger. Have you established what exactly it's measuring? Have you then examined that process to verify it's operating within parameters?
e.g. CO² may have to be within 0.5% -1.0%, else engine check light is thrown. Focus would then be on why CO² has increased...
Old Jun 8, 2023 | 06:28 PM
Harvlr's Avatar
Being a 2002 P38, it has the same engine and ECU as a Discovery 2. I would post your question in the D2 section of this forum as it gets a lot more traffic than the P38 section.
Old Jun 9, 2023 | 08:23 AM
ox12345's Avatar
4wd High
According to the scan tool I have it reads at a steady .45 volts. All the others O2s voltage fluctuates between .4 and maybe .8 volts so something is off on the one. Could a vacuum leak on bank 1 be the issue?
jbullard
Sep 20, 2021 09:08 AM
me6067
Dec 15, 2014 06:49 PM
Garrett
Feb 6, 2011 07:51 PM
newtolandie
May 14, 2009 02:20 PM
