Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
P38 internitant Cold Starting
Old Jan 10, 2025 | 12:22 PM
bolte's Avatar
5th Gear
Default P38 internitant Cold Starting
I have a 2002 Range Rover P38, having starting problems only when it is cold, otherwise starts and runs great. Recently replaced ECU and Fuel Pump but still will not start on cold mornings. I am able to start if I spray starting fluid in the air box, takes two times but then starts, which makes me think it is a fuel starvation problem. Has anyone experienced this problem and if so could you advise the cause was and fix?
Outmans
Dec 13, 2021 02:01 AM
Outmans
Peter Spearing
Aug 26, 2017 07:02 PM
william
Nov 20, 2007 07:48 PM
marog
Oct 4, 2007 01:49 AM
