Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
2010 TDV8 cranks but doesn't start
Old Oct 21, 2021 | 03:41 PM
aaronjb's Avatar
Default 2010 TDV8 cranks but doesn't start
I've done a ton of research on this and all roads seem to lead to 'dead ECU' somewhere on the CANBUS, but .. I haven't found which one yet. Let me describe the symptoms:
I have a christmas tree full of warning lights on the dash, faults for .. lots of things. The engine cranks but doesn't fire (or even attempt to).
If I reset the faults and immediately read them, these faults will always be there:
ATCM-Terrain Response
U0139-00 (2F) Lost communication with the suspension control module B
( on 20-10-2021 18:07:59 at 185626 km )
BCM-Body Control
( on 20-10-2021 18:08:00 at 185626 km )
IPC-Instrument Pack
U0104-00 (2F) Lost communication with speed control module
( on 20-10-2021 18:08:05 at 185626 km )
U0133-00 (2F) Lost communication with dynamic response module
U0139-08 (2F) Lost communication with the suspension control module B - General failure information - bus signal/message failure
RLM-Suspension
( on 20-10-2021 18:08:11 at 185626 km )
The usual suspects are the TCCM, however it seems that for the 2010 MY it was moved to the drivers side rather than stuck to the engine ECU, and is now the other way up - so the connectors don't fill with water. Of course, it could still be the fault..
PCM comes up in a lot of threads and something is pointing me to that at the moment - reading the live data (engine off, obviously) I see this (the battery was a little flat here but even a new battery doesn't change things):
Does anyone know what the "Battery voltage" should read? All other modules read ~12V but the PCM reads ~5V which seems wrong. Likewise the DC/DC Converter voltage reads ~7V; does anyone know what that should read when the ignition is on but engine isn't yet running?
Old Oct 31, 2021 | 02:37 PM
Patrick Cox's Avatar
Definitely battery
Richard Gallant
Jul 11, 2022 10:53 AM
tanman1234
Sep 24, 2021 10:34 AM
Tristan Stumpf
Jan 11, 2020 06:40 PM
Richard Gallant
16
Oct 22, 2019 05:41 PM
Imi39
Sep 9, 2019 11:27 AM
