Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Engine Undertray Spacer Length 2009 RR Sport HSE and others
Old Sep 23, 2025 | 09:31 AM
Taser_this's Avatar
4th Gear
Default Engine Undertray Spacer Length 2009 RR Sport HSE and others
Does anyone know or can measure the length of an engine undertray spacer part # LR014236. Mine are missing and are used at the two attachment points at the rear of the undertray using two M10 x 65mm x 1.5mm bolts. I am going to order 10.2mm ID x 20mm OD x length. I am replacing most of the undertray hardware, except for the speed nuts, with stainless.
Last edited by Taser_this; Sep 23, 2025 at 09:53 AM. Reason: grammar and punctuation
Old Oct 3, 2025 | 02:04 PM
Taser_this's Avatar
4th Gear
Why does the thread post count say two posts, but only one is displayed?
When I post this, I assume it'll read three posts and only two displayed.
Old Oct 15, 2025 | 11:38 AM
Taser_this's Avatar
4th Gear
All the posts are now appearing.
Thanks for the replies.
I purchased 25mm and 30mm 10mm ID and 20mm OD aluminum spacers on Amazon. For my 2009 Sport HSE 4.4L, of the two sizes, the 30mm works best at the rear of the tray, but it appears a 35mm would probably be the most accurate size. Currently, with the 30mm spacers, the tray is bowed a bit. With the 35mm spacer, it might be about right and be straight-across.
Hipezz01
Jan 26, 2020 04:57 PM
misterkye
Jul 16, 2011 02:24 AM
ramled99
May 23, 2010 01:24 PM
john123
Jul 23, 2008 01:26 AM
EBO
Appearance & Camping Set Ups
Feb 21, 2006 07:17 PM
