Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Hard ride / harsh suspension
Old Jun 9, 2023 | 09:42 AM
Yansats's Avatar
4th Gear
Default Hard ride / harsh suspension
Dear forum members,
My name is Yan and I'm from Ukraine. Half a year ago, I became the proud owner of a 2010 Range Rover Sport S/C. However, I've recently encountered a peculiar issue, and I'm hoping for your assistance and advice.
When driving above 50 km/h, the suspension of my car becomes unusually stiff, despite the conditions remaining the same – I'm using the same roads and maintaining the same speed. If I slow down to less than 50 km/h, the suspension regains its usual softness, but this change doesn't happen immediately, it takes about a minute or so.
We've already inspected the entire suspension but found no issues. There are no active error codes or warnings on the dashboard, and checks indicate that the control units do not require updates.
I sincerely hope for your help and advice on this matter. Perhaps someone has encountered a similar issue or can suggest what might be causing this behaviour in the suspension. I thank you in advance for any information and assistance you can provide.
Best regards,
Yan
Old Jun 17, 2023 | 05:52 AM
Yansats's Avatar
4th Gear
I've resolved the issue with the hard suspension. The problem was with non-standard tires for this car (255/55 R20), which are significantly larger than the standard tires. The profile height in the BCM block was considerably lower, the car's sensors misinterpreted the incoming information and stiffened the suspension: the car became as hard as a sports car. Initially, I tried to calibrate the accelerometer, but my laptop ran out of battery, and I left with a disconnection error from the module that controls the vehicle's roll (I might be wrong), and a miracle happened: the car stopped being stiff. There were many experiments afterwards, but the following helped:
1. Engineering mode SDD
2. Changing the data about the tire size and their circumference through the SDD engineering menu
For a week now, the car has been comfortable and only brings positive emotions.
Old Jun 21, 2023 | 02:37 PM
salvine's Avatar
Interesting. I'll look into this. Tire size is correct but the computer may be set wrong.
Old Aug 15, 2023 | 09:54 PM
obiwantoby's Avatar
Is there an equiv setting in IID Tool GAP? Be nice to trick it into softer settings - or just make sure it is set appropriately as wheels change. I suspect this could be mitigated as well. https://www.rangerovers.net/threads/...2/#post-385301
mlw911
Aug 17, 2022 04:38 PM
Bazza
Sep 29, 2021 07:58 PM
Bizer
May 18, 2021 12:38 AM
Abdullah
Nov 27, 2020 05:14 PM
RR85
Oct 23, 2009 10:28 AM
