Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
possible CAN bus issues?
Old Jan 31, 2020 | 07:01 PM
Westwood's Avatar
Default possible CAN bus issues?
I was driving when all the electronics in the truck went bonkers with no warning, the engine kept running fine, but the audio head unit read an error then shutdown, the nav screen died, HVAC died, dash lit up with many error lights, flashes came on, turn signals would not work, the time and temp on the dash was: --:-- and Im sure a lot more stuff I don't remember. I was able to turn around and drive back home, turned off the truck and it never started again. I have a nancom and was able to read these error codes:
FAULT 1 OF 20
ECU: Instrument Pack
CODE:U0010
Medium speed CAN communication bus
(INTERMITTENT)
BUS SIGNAL/MESSAGE FAILURE -
BUS IS OFF.
FAULT 2 OF 20
CODE:B1A87
Battery disconnection/electronic control unit reset
(PENDING)
ALGORITHM BASED FAILURE -
EVENT INFORMATION.
FAULT 3 OF 20
ECU: Engine Management
CODE:U0167
Lost communication with vehicle immobiliser control module
(INTERMITTENT)
GENERAL FAILURE INFORMATION -
NO SUBTYPE INFORMATION.
FAULT 4 OF 20
ECU: Transfer Case
CODE:U0155
Lost communication with instrument cluster control module
(PERMANENT)
MISSING A MESSAGE.
FAULT 5 OF 20
ECU: Automatic Gearbox
CODE:U0155
(PERMANENT)
MISSING A MESSAGE.
FAULT 6 OF 20
ECU: Parking Brake
CODE:U0101
Lost communication with transmission control module
(PERMANENT)
MISSING A MESSAGE.
FAULT 7 OF 20
ECU: Parking Brake
CODE:U0155
(PERMANENT)
MISSING A MESSAGE.
FAULT 8 OF 20
ECU: Ride Level
CODE:U0416
Invalid data received from vehicle dynamics control module
(PENDING)
SIGNAL IS INVALID.
FAULT 9 OF 20
ECU: Steering Angle Sensor
CODE:U0122
Lost communication with vehicle dynamics control module
(PERMANENT)
MISSING A MESSAGE.
FAULT 10 OF 20
ECU: ABS system
CODE:U0155
(PERMANENT)
MISSING A MESSAGE.
FAULT 11 OF 20
ECU: All Terrain Control
CODE:U0416
(PENDING)
COMPONENT FAILURE -
UNEXPECTED OPERATION.
FAULT 12 OF 20
CODE:U0421
Invalid data received from ride level control module
(PENDING)
COMPONENT FAILURE -
FAULT 13 OF 20
ECU: Front Lighting
CODE:U3000
Control module
(PERMANENT)
SYSTEM PROGRAMMING FAILURE -
IS NOT CONFIGURED.
FAULT 14 OF 20
ECU: Parking Assist
CODE:U0155
MISSING A MESSAGE.
FAULT 15 OF 20
ECU: Parking Assist
CODE:U0140
Lost communication with body control module / Loss of communication with central junction box
MISSING A MESSAGE.
FAULT 16 OF 20
ECU: Parking Assist
CODE:U0300
Internal control module software incompatibility
IS NOT CONFIGURED.
FAULT 17 OF 20
ECU: Tyre Pressure
CODE:U0300
(PERMANENT)
FAULT 18 OF 20
ECU: Tyre Pressure
CODE:U0416
(PERMANENT)
FAULT 19 OF 20
ECU: Audio Front Control
CODE:B1A56
Antenna / Driver seat slide control relay failure / Slide relay output is not equal to feedback
(PERMANENT)
GENERAL ELECTRICAL FAILURE.
FAULT 20 OF 20
CODE:U0300
(PERMANENT)
IS NOT CONFIGURED.
The scanner could not read the touchscreen, HVAC, audio amp, and phone, it it took several tries to get it to read the Audio Front control, and Body Control
To my untrained eyes it looks like a CAN bus failure of some sort thats causing everything else to freak out. Anyone have any ideas where to start?
Old Feb 1, 2020 | 03:38 PM
futchs's Avatar
3rd Gear
Same issuessssssssssss..
HELP HELP
Old Feb 1, 2020 | 04:10 PM
Westwood's Avatar
new developments, so on a hunch I removed the front head unit and completely took it apart to see if I could find any bad capacitors or something. Everything looked fine, put it back together and when I put it back into the car everything worked! I was able to start the car, it idled for about 1 min before all the electronics died just like before. So my though is something is wrong with the head unit and causing the bus not to communicate. I'll head to the junk yard monday and swap out the head units and see if that fixes it. and report back my findings
Old Feb 3, 2020 | 08:01 PM
Westwood's Avatar
the head unit theory was a bust. I got the truck to start randomly today and was able to do a clear and scan before it errored again and these were the errors with the truck working. (I marked out the unrelated errors I already know about)
FAULT 1 OF 8
CODE:P0116
Engine coolant temperature - circuit range/performance
(PENDING)
GENERAL SIGNAL FAILURE -
SIGNAL STAYS HIGH.
FAULT 2 OF 8
ECU: Body Control
CODE:B1C32
Steering column tilt solenoid
(PERMANENT)
GENERAL ELECTRICAL FAILURE -
CIRCUIT OPEN.
FAULT 3 OF 8
ECU: Body Control
CODE:B1C33
Steering column tilt feedback signal
(PERMANENT)
FREQUENCY MODULATION/PULSE WIDTH MODULATION FAILURE -
INCORRECT, HAS TOO MANY PULSES.
FAULT 4 OF 8
ECU: Body Control
CODE:B1C34
Steering column telescope solenoid
(PERMANENT)
CIRCUIT OPEN.
FAULT 5 OF 8
ECU: Body Control
CODE:B1C35
Steering column telescope feedback signal
(PERMANENT)
FAULT 6 OF 8
ECU: Parking Assist
CODE:U0155
MISSING A MESSAGE.
FAULT 7 OF 8
ECU: Parking Assist
CODE:U0140
MISSING A MESSAGE.
FAULT 8 OF 8
ECU: Parking Assist
CODE:U0300
IS NOT CONFIGURED.
Could it be the parking assist ECU that has a short? I will have a look at it tomorrow
Old Feb 5, 2020 | 08:40 PM
Westwood's Avatar
FIXED!!
It was the parking assist unit. I crawled into the back of the truck and removed the unit, it was super easy. I still had errors after i removed the unit until I reset the truck. I used my nancom to reset, but I'm sure disconnecting the battery for a sec would have worked too.
On i side note, It seems like bad engineering that one faulty accessory would cause the entire vehicle to become inoperable. You would think land rover would have used a communication protocol that would ignored erroneous signals coming from a broken node on the BUS network, or at the very least used a separate BUS for missions critical systems... oh well, glad its working again
Old Feb 10, 2020 | 07:35 PM
dgi 07's Avatar
Originally Posted by Westwood
FIXED!!
You would be suprised. All the manufacturers that run can communication have the same issues. Everything is connected and interlooped so one bad control unit can bring the whole system down.
Old Jul 13, 2020 | 12:41 AM
samer0214's Avatar
FIXED!!
Reviving an oldish thread as I'm having similar issues. I already know that I have issues with the Parking Brake Unit, as I'm currently not using the parking brake.
I bought the truck with a broken parking brake unit, and all other hardware completely missing. Not sure why the previous owner removed the parts, but regardless, the truck now has a complete replacement module, except for the brake shoes and associated hardware. I of course can't apply the brake yet because of the missing parts. I'm having a hard time associating the failure of the CANBUS/dash with the in-operation of the parking brake, especially that the module has been replaced.
1) Can you please confirm that your issues are still resolved after a few months
2) I gather from your post that you removed the unit completely, and that fixed your issue. Can you please confirm that?
3) Finally if so, can someone shed some light on why I would have similar problems with the CAN BUS, if I have a replacement unit in place? Surely all the CANBUS needs to know is whether the unit is in proper working order, but doesn't really care if the brake shoes are missing, or the actuator cables are connected to brake shoes??
Thank you - Samer
2007 RRS
2003 Disco II
Old Feb 4, 2023 | 10:34 PM
eurotechinno's Avatar
Hello,
I have many of the same issues with my 2006 LR RR. How did you go about resolving the issue? My thoughts are to test canbus resisitance between high and low; at each module on BUS; etc.
Steve
Old Feb 9, 2023 | 07:45 PM
longtallsally's Avatar
I’m gonna try and keep this thread alive as well as the original post might as well have been me or my wife writing it!!!!!
’11 RRS SC. All that the OP described is EXACTLY what her car is doing. We’ve dumped a BUNCH of $$$ into this: CJB, new cluster, now a new Indy shop is looking at the KVM.
Well, since we bought it only a year old from. rover dealer and still under factory warranty, the parking sensors have been wonky.
I’ve provided this to the Indy shop (gods in the Rover world) and they are investigating. But if someone has some updates here (OP????) you’d be a hero.
Old Feb 10, 2023 | 07:11 AM
Hello,
I would check the engine grounds. And, the grounds generally on the truck. Get a diagram (I have found diagrams, but they are not accurate with regard to color codes); have to ask around on the forum and let me know where you find them. You can buy a probe that will verify the ground it good; it connects to the battery for power. Once that's done, verify positive connections at battery and it is putting out 13V. Once that's done, do the following...
Get a pin diagram of the OBD port. Then locate "CAN BUS Troubleshooting guide (with video)" by Enovation Controls Help Center. Follow the directions for the tests and let me know what you find. I would use the chassis/signal ground (pin4 ) for your measurements when a ground is needed.
Let me know what you find? Write the result down.
Euro Tech
wehtjns
LR4
16
Jan 30, 2024 02:41 PM
Rufflyer
Aug 12, 2019 07:45 AM
bluetick
Jan 6, 2019 08:31 PM
Jst4fun
Oct 29, 2013 09:24 PM
