Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Transmission Range Fault, Engine Fault, HDC Fault, Parking Brake Fault
Old Oct 10, 2018 | 07:46 PM
abrahamd's Avatar
3rd Gear
Default Transmission Range Fault, Engine Fault, HDC Fault, Parking Brake Fault
Hi Gurus,
Please help. I am new to LRs, so I have this project car, a 2006 RRS with shy of 70K miles. It was flooded during hurricane Harvey (A little above the interior floor). I am having a couple of lights on the dash and I help diagnosing this faults so I can fix them.
First of all, I am having a parasitic draw. (I am suspecting due to the starter being bypassed and hot-wired to a button that I push on to start the car after I turn the ignition to position II, Though I may be wrong)
Here are the faults I see in the instrument cluster/message display:
Transmission Range Change Not Available
Engine System Fault
Transmission fault: Limited Gears Available
Parking Brake Fault (Parking brake sometimes engages, and most times does not disengage until I keep trying for a long period of time)
HDC Fault System Unavailable (This shows up as soon as the terrain response selector indicator light goes off)
Finally, there us a big "E" on the gear selector indicator
I would appreciate if I could get help with this. I am in the DFW area.
Edit:
Here are the codes I have pulled from the vehicle using iCarsoft i930.
Transfer Case Module codes:
U0126
U0101
P0561
P0562
U0100
U0155
Parking Brake Module Codes:
U0122
U2002
Steering Angle Sensor Module Codes:
U0300
Instrument Pack Module Codes:
U0001
U0010
U0100
U0101
U0102
U0132
U0182
U0159
U0127
U0138
U0184
B1A00
B1A87
B1A00
Air Suspension Module Codes:
U0416
U0100
U0126
U0101
Others:
P0036
U0101
P0071
Old Oct 10, 2018 | 09:00 PM
If you have the codes pulled by a land rover specific reader we can be of more assistance. Otherwise there is a host of possible faults especially in a flood victim with wiring that has been cut into for a starter button
Old Oct 11, 2018 | 08:04 AM
abrahamd's Avatar
3rd Gear
Thanks ArmyRover, I have edited the original post to include the codes I pulled from the RRS.
Old May 7, 2023 | 02:15 PM
Awagner's Avatar
3rd Gear
Were you able to find the solution to this problem? I'm having the same problem but have not cut wires or been flooded.
Old May 7, 2023 | 05:18 PM
abrahamd's Avatar
3rd Gear
Hi @Awagner I have not been able to fix the problem, and I am still needing help. Please keep me updated if you find a solution. Thanks.
Old May 7, 2023 | 05:32 PM
Awagner's Avatar
3rd Gear
I will. Thanks.
Tonko007
May 6, 2018 03:01 AM
06Range
May 8, 2013 09:01 PM
rgreenwell8962
Oct 12, 2007 09:13 PM
