Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
DAB problems
Old Jan 23, 2021 | 05:05 AM
andymorris38's Avatar
Default DAB problems
Hi. I am having trouble with my DAB signal. Keeps on coming no reception. Any ideas?
Old Feb 24, 2021 | 03:26 PM
David Nguyen's Avatar
4th Gear
Same problem here. It cuts in and out but not as frequently as before when I got the car.
During that time I did unplug the DAB module in the rear boot and rechecked the antenna connections in the roof section though. All tight and not loose.
I asked Dealer and they said it is usually because of buildings and interference however where I am and where I drive, there aren't many tall buildings or towers that interfere with the DAB reception. I drive in open roads and clear skies in metro Perth.
DAB reception here in Perth I believe is well covered so can't imagine it being not enough towers. I think it might have to do with my RRS being 2015, so software or hardware outdated?
I want to update the headunit to see if it helps and also update the nav on it but dealer said not needed unless really required? Does anyone have the update done it them selves at home ?
So even after trying to figure it out I still get reception dropouts at random and can't do anything about it.
Old Jul 5, 2022 | 07:27 AM
NealeP's Avatar
David, Did you get to the bottom of your DAB reception?
Mine has always been useless so I thought I would change the two amps up in the rear spoiler. The FM signal is much better and I thought the DAB was too, but unfortunately its still rubbish. When I tune the DAB with the engine running it goes straight to 99% and complete in 2-3 seconds. If i search with just the ignition on, it searches fine and I get great reception. Therefore it seems to be related to having the engine running in my case. Any pointer if you've resolved yours would be great. Thanks Neale
Old Feb 14, 2023 | 02:22 AM
traffictech870's Avatar
What is a DAB signal?
Thanks.
Old Feb 16, 2023 | 06:02 AM
siyadsalah's Avatar
8th Gear
Thanks.
Digital Audio Broadcasting
Old Feb 20, 2023 | 11:54 PM
Nothing to laugh about.
I've never heard the acronym DAB.
Thanks for the response.
Old Feb 21, 2023 | 12:30 AM
siyadsalah's Avatar
8th Gear
Sorry!
ebarry
Dec 27, 2020 06:55 PM
alpinacsi
Feb 7, 2018 08:45 PM
jussnb
Aug 13, 2013 09:19 PM
sideburnbill
Apr 25, 2010 04:45 AM
billinohio
Mar 14, 2007 11:43 AM
