Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
DEF Fluid Issues
Old Feb 28, 2023 | 05:41 AM
Thenigeman's Avatar
Originally Posted by andylstarr
I have a 2016 TD6 Range Rover. Love it, except for DEF. For past two years, in all cycles but one, I get DEF quality message with no-starts after 249 miles. The dealer has struggled to find root cause and do anything but top off and reset. Finally the dealer just replaced the entire tank including injectors. Hopefully that will work, but interested in other ideas?
How much did they charge? Mine here is saying $5000 installed...except there aren't any in the country! 60 miles to go before no restarts!! I.e. dead in the water
Old Feb 28, 2023 | 09:35 AM
wingding's Avatar
8th Gear
Default been awhile since i was here
the dealer, when i had the 'death code 249mi' message a second time, called to say the catalytic convert needed to be replaced, i exploded, knowing how much they cost, he told me it was under warrenty, apparently the code stems from the 'spray pattern' or 'quality of def fluid' problem, it had to be a flash of the computer to resolve, and i had to pay for a service check, if i remember it was like $180 ... , they checked the DEF quality and spray pattern .. both were fine, , don't let them tell you the tank needs to be replaced, have them flash or update the computer(the root problem) ... if you do not get anywhere with them, reply to this post, i'll try and connect you to my dealer who helped me here in philadelphia area, they are in willow grove off the PA turnpike ... BTW, now that i think about it, the car has another 5k miles on it since the problem
Old Dec 3, 2023 | 10:48 PM
Thegiant's Avatar
Default DEF Issues
I read your message and I have the same issue. Went to LR dealer and still having the dreaded DEF Quality warning lite and 250 left to no start. wonder if your car ever got fixed and if so what was the root cause.
Thank you, Andre
Old Dec 3, 2023 | 10:54 PM
Thegiant's Avatar
Third time now with a Quality DEF warning with 250 mile warning. They want to change the tank now but don't know if the LR dealer is just shotgunning the issue. Any info would help.
Thanks, Andee from Atlanta
Old Dec 4, 2023 | 08:26 AM
wingding's Avatar
8th Gear
my resolution was a 'reflash' of the ECM
the previous threads said to remove the spray nozzle and make sure it's clean( i did this ), it can crust over, so, easy job to do on your own ... the spray pattern, you won't figure it out ...
plz have them start there
it only cost an hour labour
but
as you'll note in the threads, it can come back unexpectedly (< 500mi) ,,, next was replacing the cat ... i flipped out over this, but, it was covered under warranty
been 25k mi, no problem ...
plz keep in touch if you've got any questions .... it's frustrating
Old Dec 17, 2023 | 07:57 AM
sandeep's Avatar
but
which year is your r. Mine is having the same issue after 2nd time and I don’t think I have warranty
Old Dec 17, 2023 | 03:22 PM
wingding's Avatar
8th Gear
2016 RR sport td6
i'm in the phila area
where are you
my dealer/service was great ...
yes you are outta warrenty now .. only 8 yrs... wait, depends on the build date
they changed the cat and i've not had a problem since
Land Rover Willow Grove
900 S York Rd, Willow Grove, PA 19090
(215) 443-5900
Joe Egan - helped with DEF issues
Old Dec 19, 2023 | 06:56 AM
sandeep's Avatar
2016 RR sport td6
where are you
(215) 443-5900
Thanks, I am from Rhode Island. Today I will call him
Old Dec 19, 2023 | 08:28 AM
wingding's Avatar
8th Gear
i don't know if i'd travel that far for a resolution, but, haven't you heard from any other members here of dealers closer to your residence that are responsible ?
Old Oct 18, 2024 | 06:10 PM
Mmlee1's Avatar
Default 2016 Range Rover TD
2016 RR sport td6
where are you
(215) 443-5900
I am new here! Long time Jag XF owner...Wow, Joe is my boy! Talked to him today, been dealing with Joe for years! Small world. I have an XF, but buying a 2016 Range TD6, but a little skeptical as Joe told me they have big problems with DEF system after they get a little older. JAG Main Line said go for it, it's like any car, as long as you take care of it. Should I still get one? 95k on it. Immaculate service records, but scared! It will be my first dieselThoughts?
