Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
Range Rover Sport 2015 - Service Required
Old May 22, 2023 | 03:35 AM
Favour17's Avatar
Default Range Rover Sport 2015 - Service Required
My car is due for a service and the service is already booked. I now get these other notifications showing up on my dashboard along with the "service required" flashing with them:
- stability control not available drive with care
- ebd fault
- park brake fault
- emergency brake assistant not available
- hdc not available system fault
- abs fault
Do I take it these are coming up because it's due for a service & will be sorted when it goes in for the service or are these problems that need to be addressed asap? My service is booked in a week's time & no earlier date is available. Do i keep driving or do i avoid until service day? Thanks in advance xx
Old Aug 7, 2023 | 10:34 AM
Championsound's Avatar
Default RRS 2016 I have exactly the same problem
I have had the same problem for a while.
E Difff not available
Park Brake Faut
Stability Control not available Fault
APTC Not available
HDC Not available System fault
Adaptive Dynamics Fault
Emergency Brake Assist not available
I took the care to a Range Rover dealer and I paid for a diagnostic check, they couldn't locate the problem and wanted to keep it indefinitely at £XXX per hour . Because it was intermittent I decided to drive on.
I read on a few forums that it could be the battery or ground points, the battery has been replaced and the ground points check it still occurs.
Any help or pointers would be appreciated.
ToiletDuck
Jun 29, 2023 07:20 AM
BrandonLewisSMU
Jan 25, 2023 06:59 AM
Coldwater
May 16, 2021 11:56 PM
chesterkins
Discovery Sport
Jun 17, 2019 06:41 PM
bigugly82
Aug 22, 2007 01:08 PM
