Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
rattle/buzzing sound in dashboard
Old Jul 24, 2019 | 04:38 PM
Nav Mallhi's Avatar
8th Gear
Default rattle/buzzing sound in dashboard
hello everyone.
i have a 2016 diesel sport
every morning upon startup and changing from park to reverse there is rattle noise coming from the dashboard..
i have uploaded a video and its the trrr/trrr sound.
the tech at dealer said there was loose clip in fuel lines but the sound is still there.
can any one advise if they have this issue.
Old Jul 24, 2019 | 05:26 PM
Nosugar0carbs's Avatar
Sound like the heads up display tizz noise.
Old Jul 24, 2019 | 05:31 PM
Nav Mallhi's Avatar
8th Gear
kindly, elaborate. it does come on only in the morning and goes away once the vehicle is warmed up.
is it something that can be fixed ?
Old Jul 24, 2019 | 05:34 PM
The rectangular section on the driver side above the cluster where it displays vehicle speed and info. Something that can be fixed....the dealer more than likely won’t want to dissassemble the dash just to hopefully fix the HUD
Old Jul 24, 2019 | 05:36 PM
Nav Mallhi's Avatar
8th Gear
thank you. that could be the issue and yes, i would not want the dash ripped apart.
i will try tomorrow morning and see if i can turn the hud off. and see if the noise goes away.
thank you kindly
Old Jul 25, 2019 | 09:55 AM
Nav Mallhi's Avatar
8th Gear
hello. upon further investigation...the sounds seems to be coming from somewhere near the fuel lines...its worse in reverse gear...here is a video of the rattle in the engine bay...
Old Feb 3, 2020 | 03:48 PM
LoobyLou68's Avatar
4th Gear
I had the same issue, turned out to be the brake pipe touching against the the brake server, the rubber boot was not in the correct place! So metal onto metal.
Old Feb 3, 2020 | 03:49 PM
LoobyLou68's Avatar
4th Gear
Old Feb 17, 2020 | 04:51 PM
Skuznets2004's Avatar
I have exactly the same issue with my 2016 supercharged. Were you able to fix it?
Old Jun 12, 2020 | 11:22 AM
LoobyLou68's Avatar
4th Gear
I spoke too soon, I still have the issue. Car booked in next week, fingers crossed this time it will be fixed.
