Range Rover Velar Talk about the Land Rover Range Rover Velar within.
2018 Velar Daytime Running Light Issue
Old Feb 23, 2023 | 11:17 AM
Enygma's Avatar
Default 2018 Velar Daytime Running Light Issue
First time to the forum…was hoping to get some insight if anyone’s experienced the same issue.
Have a 2018 Velar where the passenger side DRL turns on but shuts off after a couple seconds. Took it to the dealer and they advised I needed to replace the headlight assembly.
Ended up purchasing a used light which was working fine for a day then ended up with the same problem. High beams/low beams work fine…issue seems to only be with the DRL. Found a video on YouTube where someone else seems to have the same issue.
https://youtu.be/k2ZvAaFx3Hk
Defender90NY
Jul 16, 2022 11:40 AM
kylltyme1
Dec 20, 2019 04:09 PM
Quagaar
Jun 23, 2017 11:45 AM
wick_60010
Jun 28, 2011 02:58 PM
tsuami1
Mar 9, 2009 07:33 PM
