Headlight issue
Old Nov 20, 2019 | 05:11 PM
kylltyme1's Avatar
8th Gear
Default Headlight issue
Hi All!
I searched the boards for some advice on an issue I am having with my headlights ('00 Disco II) but came up empty. Hopefully you all can help me out.
My Issue:
Driver Side main lamp only works with high beams, no driver side fog lamp, yet the city light works fine. I swapped the bulb thinking it may have been the issue, nothing. I swapped the fuse, again, nothing. I even jiggled the harness/connectors behind the lights (recommendation on a thread here) and still, nothing.
Any advice would be greatly appreciated!
Thanks
Old Nov 20, 2019 | 05:18 PM
Best4x4's Avatar
Get a meter & see if you even have 12v at the light. Sometimes those H4/9003 connectors can fail or corrode. Using a metet will tell you very quickly if you have 12v at the light or not.
Old Dec 20, 2019 | 04:09 PM
kylltyme1's Avatar
8th Gear
I finally had a chance to meter the connectors. I get 12v on both driver and passenger in high beam and 12v passenger 11.3v driver at normal. I swapped the fuse and it didn't change anything. Any suggestions?? I seem to be doing more head scratching than anything else at this point
T10HEAT
Aug 13, 2019 06:18 AM
ratherman
LR2
Apr 15, 2019 04:32 PM
DakotaTravler
Mar 3, 2019 03:46 PM
iconoclast
LR4
Nov 11, 2017 01:46 PM
tsuami1
Mar 9, 2009 07:33 PM
