Mag Lite Mount
#21
My subs blew about a month ago, so thats what got me thinking about getting one, i don't really notice a difference in sounds so im not about to spend the money to replace it, i'd rather drop $100 for the metal door panel.
Your pic didn't work, but I know exactly what your taking about on Jeffrudy's set up!
#22
#23
That is what happened to me. I bought it with blow subs. i replaced them with some 6" subs i had laying around but didnt like the way they fit so I just got the SS plate from Columbia. very happy I did. If you do go to install it i would make a suggestion to use some sort of damper between the SS panel and the interior of the gate becuase you will get of a lot of rattle when hitting bumps. I used a piece of cardboard as a temp until i install my swing out table which I will bolt thru the panel and gate holding everything in place.
Did you reroute your subs to somewhere else or just remove them altogether?
#24
Dude, there are tons of more powerful lights for alot cheaper. Hell I got one that is magnetic that swivels and it works great. Of course I have four lights and one clamshell that is charged from inside the vehicle.
A maglite is too big and clumsy and wont do squat when you got a flat tire.
#25
...I'm just going to rip down the Mag Lite and the mounts and throw it all in the garbage because apparently they're the worst
I have a headlamp for night-time tire changes/peaking under the hood if needed. I'm not sure what sort of Mag Lite's you guys have been using, but the Mag Lite has a super bright beam that lights up things far far away. Any reasonably priced LED is great for lighting things up close like engine bays, etc, and that's why I have one of those in the glove box, but sometimes it's nice to have a little range.
Plus I know where it is if I need it, it's out of the way, I could beat someones a$$ with it, and I happen to think it looks cool.
#26
they make LED's for your keychain. I like being able to stick 4 d batteries in my LED and it sits there thru the winters and summers and never gets dull. If i need it to wack something it does that pretty damn well too.
#27
If there are full size Mag-Lites with LED's, that would be pretty sweet. I haven't messed with a Mag in years. In my experience the bulbs didn't hold up that well to the abuse that you expect to put something that chunky and heavy through. And we put ours through the ringer, for sure. But I would definitely want to have a smaller task light on hand, as well. Just my opinion.
I think it's a pretty cool thing you did. Personally, I'm a fan of these smaller mods. They're cheap, quick and easy, and can come in quite handy. Goes to show you don't have to spend a ton of money to make a very functional vehicle.
#28
That's another reason I like it mounted where the driver's oh-****! handle was.
bavarian_range89
10-31-2007 01:51 PM
solihulldiscotruck
Member Group And Special Buys
06-04-2007 04:20 PM
