ROAMING WITH FRIENDS Make friends, socialize, share pics and other non technical threads.
Range Rover vs. discovery
Old Jul 14, 2015 | 09:10 PM
jrwalk1651's Avatar
Default Range Rover vs. discovery
Gents,
Question here...I was doing a little wheeling with my father last weekend. He has a 1995 Range Rover county classic and I have a 1999 discovery II. We approached about a 45 degree climb (rough estimate) that was slippery and muddy. We both have newer BFG KM2 and he was able to muscle his way up it no problem and I had to lock my differential to get up it (easy as cake after diff locked) what's the reason this could be? We're both curious. Also, the D2 has a 4" lift and the RR has a 2" lift. Ideas?
Old Jul 29, 2015 | 02:13 PM
Shiftonthefly1's Avatar
The Borg warner case is "locked" when it's is in low gear.
Old Aug 4, 2015 | 08:44 AM
You might want to look into your loft, no one makes a 4" lift kit for a D2.
Also, to prevent wearing out your brake sooner then you want, keep you CDL locked for any trail or section that requires more traction and save burning out your pads which is also less effective when traction is needed.
Old Aug 4, 2015 | 04:39 PM
jafir's Avatar
The rear suspension setup is better on RRC too. The tires are more likely to stay in contact with the ground. But most was probably the transfer case.
Old Aug 4, 2015 | 08:49 PM
antichrist's Avatar
There's also the issue of driver skill.
Old Aug 5, 2015 | 08:42 AM
drowssap's Avatar
The RRC is simply a better vehicle
Old Oct 12, 2015 | 09:16 PM
jrwalk1651's Avatar
Just wanted to follow up with everyone, I contacted the previous owner of my D2 it has the 2" terra firma lift and the reason it was lacking off road was the shocks in the back were stock and completely shot...no rebound and didn't allow for any flex. I replaced them with the terra firma +2 shocks and it made a world of difference! However the RRC is still a beast!
Old Oct 13, 2015 | 08:08 AM
TOM R's Avatar
Air down tires, larger footprint better traction
Old Dec 19, 2015 | 07:32 PM
Ole Miss Texan's Avatar
Just for a little reassurance if the last owner had originally told you it was lifted 4" it could be from a 1/2" sag on stock suspension. So if he did a 2" lift plus 32" tires that would be 3.5" on top of stock position (so 4" from its old sagged position). Bet you love it more with those new shocks on there
badfysh
Oct 23, 2012 10:45 PM
Lincoln Tarantino
Nov 14, 2011 10:41 PM
ORLANDOM
Mar 23, 2010 08:18 AM
nextelsucks
Appearance & Camping Set Ups
May 18, 2008 08:58 PM
nextelsucks
Mar 28, 2008 09:25 PM
