ROAMING WITH FRIENDS Make friends, socialize, share pics and other non technical threads.
Traction Control in snow DI vs FJ
Old 01-13-2012 | 10:10 AM
leadfoot's Avatar
Default Traction Control in snow DI vs FJ
We have had a few inches of snow in the past few days and I have been driving alternatively the Land Rover DI and the Toyota FJ and definitely don't like traction control for me. I am sure traction control (T/C) is a good thing for the new generations that learn how to drive with it. (Of course I was tempted to say for the inexperienced driver the T/C is better, but I won't say that) For me the T/C is no help whatsoever. Despite the fact that the FJ and the LR are different cars and therefore will drive differently, I feel much more in control on the Land Rover. I was in an open space, pushing them to their limits, and once skidding and drifting, the LR comes back in control much faster than the T/C equipped FJ that would fishtail a couple more times before gaining traction again. Both cars are permanent 4WD and both of my cars have same tires. With the central differential open, the land rover is very predictable and easy to control. The FJ on the other hand is just annoying with the T/C. Once I lock the central differential, in the FJ, this disconnects the T/C, both cars are almost identical on their behavior. It is probably a sign of getting old.
Old 01-13-2012 | 11:50 AM
yloDiscoII's Avatar
DI's DON'T have traction control....so of course it wouldn't be any help
...I'm assuming you are just talking about the TC in the FJ? If you're easy on the right pedal, the DII's traction control system in the snow is pretty solid. If you 'goose' it too much the back end likes to slip out.
Old 01-13-2012 | 12:42 PM
hilltoppersx's Avatar
D2 TC + cdl = win
Old 01-13-2012 | 04:04 PM
leadfoot's Avatar
Rob, I know my DI pretty well. I wrote assuming you all knew it too. Yes, I am talking about the FJ with T/C vs the DI without, which was the whole point. I don’t like T/C.
Ed, My formula is shorter DI=WIN. LOL Cheers.
Old 01-13-2012 | 04:42 PM
yloDiscoII's Avatar
Yeah, I was just bustin your chops
My buddy at work also has an FJ Cruiser, so I'll have tell him about the "research" you did.
Old 01-13-2012 | 06:12 PM
I dont care for TC either.
On my Sprinter you could turn it off at speeds below 35mph, faster than that and it turned back on.
It not only applied the brakes it also reduced engine power to prevent wheel spin, I would get stuck driving over a 1ft wide snow berm, it applied the brakes and cut power so fast you would almost hit the windshield.
Turn it off and no problems, you could spin the tires to heat them up and melt ice to gain traction again, stuck on ice with it on and you were just stuck.
texosu1
11-23-2016 10:45 AM
HeliRy
LR4
02-26-2014 10:52 AM
gbob
02-07-2014 10:09 AM
gamecockdisco
07-12-2010 08:34 AM
rodrick smith
04-13-2007 06:09 PM
Quick Reply: Traction Control in snow DI vs FJ
