Series I, II, IIa, III Land Rovers For all Series Land Rovers
1961 series 2
Old 02-13-2020 | 06:53 PM
TOM R's Avatar
I ordered a few things from ebay buy this vehicle is on the far back burner right now
  #22
Old 02-13-2020 | 06:57 PM
wrongway's Avatar
6th Gear
I see ebay UK has a lot of parts but the shipping is killer.
  #23
Old 05-10-2020 | 07:09 PM
TOM R's Avatar
Finaly worked on this for a few hours
i swapped the rubber line and clutch slave, bled them, clutch seems to work
​​​​​bled brakes and rears now work since po had replaced alot of hard line and new rear wheel cylinders
fronts had some hard lines replaced and rubber lines look almost new , was able to bleed to the lines but the wheel cylinders look old and must be siezed and rusted solid cause no fluid out of them so wheel cylinders need to be ordered
from all the nightmare stories about bleeding brakes i had no issue, just took a little to get fluid to the rear since dry lines and new master cylinder
pics of old and new clutch slave , floor and trans hump was pulled to change the slave
  #24
Old 05-10-2020 | 07:16 PM
TOM R's Avatar
old was aluminum new is cast
  #25
Old 05-10-2020 | 07:20 PM
TOM R's Avatar
think i found the problem lol
  #26
Old 05-25-2020 | 07:36 PM
TOM R's Avatar
Little more progress, the truck was running on a toggle switch to the coil, i disasembled cleaned and repaired the key switch so i can now use the actual harness
​​​​​​i also have power to all the front lights and fuel and amp gauges one idiot light and the gauge ,lights work so we are grtting there slow, i also switched to negative ground just because, and the generator sounds horrible and has no output so on the list to goto my rebuilder
wish i took pics of the switch apart it was interesting and aparently a big issue is a loss of connection on the pin that feeds power to the ign, i was told pin needed to be ground out and make a new , i was able to use a spring loaded center punch to repress the edges and it works again for now
The Deputy (12-08-2020)
bradolivier
02-18-2019 04:18 AM
TRIARII
Build Threads
06-30-2018 09:36 PM
ls1morethanyou
04-03-2014 12:35 AM
drdeadchef
06-10-2012 09:43 AM
rbruton
Other
10-06-2010 09:12 AM
Quick Reply: 1961 series 2
