Series I, II, IIa, III Land Rovers For all Series Land Rovers
An absurd amount of exhaust is leaving my mechanics stumped
Old Aug 7, 2025 | 09:55 PM
seebeck1's Avatar
3rd Gear
Default An absurd amount of exhaust is leaving my mechanics stumped
Hello all. I've had extensive work done on my Land Rover and my mechanics (who are very qualified) can't seem to figure out why we are getting so much exhaust smoke. I've had pistons changed...new injectors..new head gaskets etc...
Just curious if anyone has any idea what this could be? Please see attached video.
Any help would be greatly appreciated.
Thank you,
Steve
File Type: mov
Old Aug 8, 2025 | 12:42 PM
XXL's Avatar
XXL
Video doesn't play for me.
Diesel or petrol?
Basic rules of thumb...
Bluish smoke = fuel/air mixture wrong. Could be ignition timing, or carb fuel/air issue, or both. For diesel, over-rich is usually more blackish. Could be injector timing or worn injector pump dosing out fuel incorrectly.
White smoke = water in combustion chamber. Bad head gasket or cracked head. Look for bubbles/pressure build-up in radiator while engine is running. Also, oil in radiator and/or water in oil.
Capable mechanics should have no issue identifying the problem. Fixing it is another story, depending on what they find.
Good luck with it.
Old Aug 8, 2025 | 12:52 PM
seebeck1's Avatar
3rd Gear
Thank you for your suggestions on this issue. It is a diesel engine. I will forward what you said to the mechanic. I'll keep the thread updated when I figure it out.
Thank you again.
Steve
Old Nov 19, 2025 | 06:09 PM
DSCan's Avatar
If the smoke is blue you likely need new valve seals.
If the smoke is black: Too much fuel, not enough air or timing with pump is wrong. Have you/they touched the injection pump?
I'm questioning your faith in your mechanics.
Defend1
Jan 14, 2025 09:46 AM
blvckcode
Jan 22, 2023 11:20 PM
Paulvfr
LR2
Feb 5, 2022 09:28 PM
sblvro
Oct 3, 2021 04:57 PM
LADisco2
Jan 23, 2018 05:21 AM
