found my first car, 1967 firebird
Old 03-18-2016, 07:49 AM
TOM R's Avatar
Opened the new rear and found this bearing, tore the rear apart and can't locate the source??
Gears are fine except 1 spider looks like someone tried to chisel it out of the rear
Also rear is 3:42 not 3:23 but still good for me
  #72
Old 03-20-2016, 06:00 PM
TOM R's Avatar
Rear is in found that 79 drive shaft is perfect fit
Waiting on bushings to finilize the perches and then paint/reinstall
  #73
Old 04-06-2016, 06:28 PM
TOM R's Avatar
So lots o progress today, springs remounted, modded perches for rear so they now set angled, fully welded the perches, cleaned rear and backing plates and primed/painted everything
Also put 4 welds on each tube at the carrier for strength as it was recommended
  #74
Old 04-14-2016, 07:34 PM
TOM R's Avatar
Well I guess even AC delco quality is bad now, brand new wheel cylinder went to bleed an fluid shooting out of one end
  #75
Old 05-19-2016, 08:19 PM
TOM R's Avatar
Pulled and rebuilt shifter, had broken part inside
  #76
Old 05-19-2016, 08:20 PM
TOM R's Avatar
  #77
Old 05-19-2016, 08:22 PM
TOM R's Avatar
New Moog front springs
  #78
Old 05-19-2016, 08:26 PM
TOM R's Avatar
Pulled fender to replace bad blower motor found 100# of rat nest all inside firewall and heater box
  #79
Old 05-19-2016, 08:29 PM
TOM R's Avatar
Welded up antenna hole in fender and old hood pin holes on hood
  #80
Old 09-06-2016, 06:17 PM
TOM R's Avatar
Bennett a while since I updated this, bought new repop hood tach, I am next in line for restoration and paint so just ordered a ton of parts
Drove a few times and seems great with the new rear , I also ended up modding the second Gen traction bars and reinstalling the air shocks
Also in pic is 1 owner 91 formula for my wife
Quick Reply: found my first car, 1967 firebird
