Catalytic Converter..............
Hi guys,
Considering purchasing another '01 Disco II. Seller says there is a problem with the catalytic converters. Says, "installed the right side cat, but the monitors won't set, no check engine light though." What does this mean???
Seller says it runs great, he is a LR tech (don't know where yet) and he has taken care of the car, has completed all work himself and has the receipts. New fuel pump, water pump, battery, good tires and brakes. Car has 135K miles, but the engine has 15K miles only. He said he will pay for smog & registration once deal is reached.
I still have my totaled '01, is it possible to use the Y pipe form my old '01? I told him I have a parts car and since he is a tech he can help me repair. Said he will ;-)
Thoughts & Comments anyone?
Cost of metal, including platinum, has gone down a LOT. you can still just about break even if you get your new cats at a discount online at advance auto with their online discount (changes monthly, find it on the top of their home page on a banner), but you wont make money any more and aftermarket replacements won't last as long. I'd recommend keeping the originals if they're still good.
And yes, they will swap right in. Get ready to put new studs in your exhaust manifolds though, or better yet replace them with bolts.
Thanks!
So youre taking the old cats from another disco, right? It its working, easier to swap the entire Y. If just the cats, it will cost you more to cu, install and weld. I am about to replace mine but I am considering getting the Y. Why, to purchase the cats and have it welded will cost just about the same if you purchase the entire new Y and bolt it yourself.
i ordered them from eBay after I went to the magnaflow website and found the proper part number. But here is the link to the ones I bought for our vehicle.
https://www.ebay.com/itm/121382229698
i also had them ceramic coated before installing to help lower temps by the prop shaft
Rosslato (02-14-2017)
