Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
Rims
Old May 3, 2018 | 11:46 PM
Aj6543's Avatar
Default Rims
hey guys, I know this section is about tires but just in case someone knows. I have a set of rims with corrosion on the inside of the rims. I was looking into having them repaired. One specialist said he could not address he corrision because afterwards the wheels would not sit correctly on the car. another specialist he could sandblast the corrision off without any issues.
Thoughts?
Corrision
Old Jun 22, 2018 | 05:35 PM
krick3tt's Avatar
Did you pull this thing out of a lake? Where does that type of corrosion occur?
If it was setting against a drum there would be nothing on the centre part of the wheel.
Old Jun 27, 2018 | 03:19 AM
t.im's Avatar
4th Gear
Thoughts?
Corrision
Well, it's really crucial to check the right land rover specialist. I mean, they should have a proper knowledge, especially on the products so they will be able to help you. If they are really expert, then they will tell the right remedy.
Old Aug 6, 2020 | 10:45 PM
Art H's Avatar
You could probably get them machined, but then you are cutting into metal and weakening the structure. I would not trust those rims.
Old Aug 7, 2020 | 09:29 AM
TexasLandmark's Avatar
.... and cost more than replacement wheels. Those are scrap metal in my mind. I would not run them.
Old Aug 7, 2020 | 07:55 PM
It was 2 years ago
Dylan L Lindauer
Jul 8, 2018 07:34 PM
carid
Appearance & Camping Set Ups
Dec 12, 2014 07:56 AM
yeaitzwill
Dec 7, 2012 06:39 PM
collector87
Dec 22, 2010 11:37 AM
dpc1192
Oct 31, 2007 05:55 PM
