Andriod or iPhone? I use an iPhone with Safari browser. Will have to try my personal Andriod when I get home (don’t take it to work to get stolen/broken).
This installation ^^^^ looks correct to me. Flush along outside edge and on the crank mating surface sufficiently.
Sixpack, did the seal actually bottom out against a machined surface/land inside the block. If there is no surface/land that the seal rest against once installed, l'd say flush is correct. It was two years ago that I did my wife's 03 (with 04 engine swap) and truth be told...can't remember what it looked like in there. But, the picture supplied by Abran looks correct and probably what l did. I've never used the Rave, besides the electrical edition, so...l'm unfamiliar with their installation process.
This is just a bugger, having to jerk that thing out again.
That rear main seal looks rubber. Man, maybe my memory is shot to heck but I thought I tapped in some sort of metal gasket for my rear main seal. Whatever it was it was so trivial to install that I never thought about it again.
I was told that the bearing end cap needs to come off prior to pushing seal on.
Yep, just how I installed mine.
The previous one was the same, only as said, cocked at an angle with the top side nearly out.
Thanks for the picture to confirm.
Per the Rave, the rear seal goes in after the rear main cap is already in.
My rear main seal tapped in the same depth as the picture without removing the cap.
I think installing the seal before the cap will damage the seal, because it could go deeper than it's supposed to, and possibly prevent the cap from seating completely, and causing the rear main bearing to spin.
Deputy, there is no edge that the rear seal butts against. Instead, it seems to be a very gradual taper, until the seal diameter is too large to go any deeper.
Hence the reason not to install the seal before the cap.
Thank all you guys again for your input.
OK, mine really does look entirely different. I went back through my old pics and the closest that I could find was this post-rebuild pic as I was about to hoist the motor back into the Disco 2.
