Inspiration needed Lets see pics of your big tire/lifted disco
Old 09-13-2018, 07:03 PM
Jason_B's Avatar
Originally Posted by gilder
This is a 2 inch lift with 265/75/16 Hankook Dynapro M/T.
This looks perfect to me. I am not a huge fan of the ascetics of the jumbo lifts on the DII. They look great on a Jeep but not as much on the Discos to me for some reason.
Old 09-13-2018, 08:14 PM
Charlie_V's Avatar
2 inch is best because it doesn't require any other changes.
3 (or 4) required an adjustable Panhard bar, extended brake lines (and brake bleed / fill), relocating abs wires, shocks, and killed my aging front driveshaft. Plus big tires slow you down and kill your gas mileage.
I just did it because I needed new springs anyway. The project snowballed.
Old 09-14-2018, 03:16 AM
99FLDISCOII's Avatar
Banned
Go BIG or Go HOME!!!!
Show your rover
Old 09-15-2018, 02:54 AM
Frank4's Avatar
Go 3”. More versatile when it comes to tire and bumper choices. You absolutely do not have to do any adjustments of the panhard bar or anything else, that’s complete misinformation perpetuated by people reposting others opinions.
3”RTE W/ 275/70R18 (33”)
Old 09-15-2018, 09:05 AM
Charlie_V's Avatar
I'm not reposting the opinions of others, or even an opinion. I have a 3" lift. It noticeably shifted my axle to the driver side. My tires (with spacers) are wider than yours. With a wider stance (and pior to bumper and winch, so taller--we have the same bumper) the shift is very obvious. The rest of my lift is on the spring perches so it doesn't affect the right / left orientation of the axle.
Beautiful Rover, BTW. How do the wires go through the roof for lights?
Old 09-16-2018, 02:00 AM
Frank4's Avatar
Well I didn’t experience any of those problems. I am still running stock length brake lines.
Thanks for the complement. I’ve tried to keep the accessories as classic and period correct as possible. You don’t have to take your wires through the roof. I ran mine from power under the hood under plastic on the A pillar. You don’t even have to take the plastic part off. Just get the wires started at the bottom of the pillar and use a panel tool to raise the inside edge as you tuck the wire in. Takes 10 seconds a side.
Old 09-16-2018, 07:56 AM
Charlie_V's Avatar
That's pure genius. I assumed everyone went through the roof.
Old 09-16-2018, 10:05 PM
Jason_B's Avatar
Looks great, any downside to removing the plastic wheel well arches? What roof rack do you have?
Old 09-16-2018, 11:14 PM
Charlie_V's Avatar
I took mine off and the only downside was getting the adhesive off.
Old 09-17-2018, 11:39 AM
Joe!'s Avatar
3" lift with BFG KM2 285/75r16s
Quick Reply: Inspiration needed Lets see pics of your big tire/lifted disco
