Changing the center dash
Other than the HVAC Controls it's very similar to the DI. Some good pics here > Discovery 1 spider/centre dash removal
Hey Lucky do you have the HK system in yours? Reason I'm asking is I replaced my HU and the engine noise is horrible. After checking all the grounds I traced it back to the factory amp as the source, so it looks like ill need to replace the amp. From what Ive researched its no easy task to put in a aftermarket amp because it requires rewiring the system. Do you have any experience with this?
