Suspension sponsored by Arnott Inc. Talk about your suspension within.
'96 suspension failure
Old Dec 10, 2008 | 10:56 PM
gardens1999's Avatar
4th Gear
Default '96 suspension failure
just bought a 96range rover with 53k miles. Had it for2 weeks andthe air suspension started malfunctioning. It would not inflate on initial startup, but would work fineafter beingdriven a mile or so. This happened a couple of times andnow the air bags will not inflate at all. the pump runs, but nothing happens. I can't finda leak in the bags or in any of the lines. Any thoughts????
Jeremy
Old Dec 24, 2008 | 12:10 AM
ldivine's Avatar
Default RE: '96 suspension failure
Do the bags look worn? You may not be able to locate the leak if the bag is folding over it (which it did on mine). Don't use the vehicle as you're putting wear and tear on the pump. You should have stopped driving it immediately when it would not inflate on initial startup... that's the warning sign you have a problem that needs to be fixed immediately to prevent other problems.
Regards
TRIARII
Jun 30, 2022 09:48 AM
Aulmeck
Feb 4, 2022 05:18 PM
Wayne
Oct 2, 2020 12:10 PM
fastrx7man
Jan 28, 2012 12:49 PM
gardens1999
Dec 24, 2008 12:06 AM
