Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
18" Alloys
Old Jun 4, 2007 | 05:04 PM
pmac's Avatar
4th Gear
Default 18" Alloys
I have a set of Range Rover 18" alloys MY2001,I foolishly bought them 4 a DiscoveryII but they dont fit,any 1 know if they fit Discovery III
Old Jun 5, 2007 | 08:43 AM
Default RE: 18" Alloys
If you bought a set of wheels from a classic, no they won't fit either a D2 or D3.
Why are you wanting to put a set of 18's on your D2, most people want to get rid of them cause 18" tires cost more, wear out faster and aren't any good off the road because of the side walls.
Mike
Old Jun 5, 2007 | 05:50 PM
pmac's Avatar
4th Gear
Thanks Mike keep that quiet I am tryin 2 sell em 2 whoever the hell I can!!!
Old Oct 27, 2007 | 12:28 PM
paranoidfreud's Avatar
6th Gear
I was told by my local Land Rover enthusiast's shopwho does all the work on my '03 Discovery se7 that I should ditch the stock 18" hurricane wheelsfor winter/offroad usageand go with 16"from a '96or newerRange Rover or a '99 Disco on. SoI got a great deal on ebay for4 wheelsoff of a '98 Range Rover. Just got back from my local tire company where they weren'tso sure that these 16" wheels would clear the brake, rotor, etc. Any guidance or infoon thiswould be greatly appreciated. Also, they said they will try and put the wheel on just to check for clearance, but couldn't today.
Thank you in advance.
Old Oct 27, 2007 | 03:15 PM
llesra's Avatar
wheels from a p38 will work on a d2 and vice versa. wheels from newer rovers work with p38/d2 with new lugs and hubcentric rings. p38/d2 rims on newer rovers work after you bore out the hub on the wheel and get new lugs.
Old Oct 27, 2007 | 03:32 PM
6th Gear
By newer rovers you mean LR3's and Range Rovers from the last few years? Also, are you saying that what I've described should be fine? Thanks.
Old Oct 27, 2007 | 04:40 PM
llesra's Avatar
yes and yes
disco12
Oct 21, 2006 10:39 AM
DiscoMike
Jul 14, 2006 12:08 AM
the doctor46
Mar 7, 2006 07:10 PM
disco12
Feb 14, 2006 11:35 PM
Randy Lover
Oct 31, 2005 02:19 PM
