Help on tire size for 18" wheel
Hello all,
Newer here, but do alot of lurking....so prepare for a newbie question.......I've read about all I can find on guys who are ready for new tires on their DII with 18" wheels. Most posts are about what brand andtread type. But I want to know only about size!
I want something larger than the 255/55/18, but not sure how big I can go being stock. I have read the 265/60 work fine and maybe the 285/60 will work.I'm just afraid of ordering a bigger size on-line then thetires end up rubbing.
Soall you experienced guysout there, can someone lay out what works and what doesn't witha stock DII?....eventually I will lift whenthe time is right (wife is the issue
) Thanks for your time and comments.
Order on-line from Discount Tire Direct. They have the lowest prices I could find and they do honor their 30 day "no questions asked" return policy. I know, I used it! Also, their tech people will tell you what's the largest tire you can fit.
Thanks guys for your posts/comments....I'm going to try the 285/60's....I done alot of google searching and saw alot of guys doing 285/60 on their stock suspension rovers....so I took the leap!
jigray3
Oct 14, 2010 06:54 PM
