How much to deflate for Sand / Rocks?
I have been driving on sand and rocks for 30 years. on sand 15 PSI. on rocks, depends on your tire wheel set up. if you have a c rated tire i would stay at 20 pounds no lower becasue of the weight of the LR. if you run a E tire you could go as low as 15, if you run a E tire with bead locks you could go as low 5 psi depending on the level of rocks you are running.
the point is, sand is easy, 15 PSI, rocks takes more thought.
on
As for what I run when wheeling, no mater if it is on sand or extreme rocks, I run 18#'s with 8" wide factory wheels and 265/75/16's, anything less then that and I tend to roll my left front tire bead.
Jay, I noticed that you mentioned a "C" rated tire and wasn't sure if that is what you are running. if so, for what it is worth, because of the Rovers weight and top heavyness, a "C" rated tire can't not be run safely. "D" and "E" rated tire are required for the stronger side wall.
I agree wiyth you 100% yuor 18 PSI is a nice one to run, i think once you get into the 35" tire range though you may find the volume of air at 18 is a little to stiff. but no matter.
yes, a c rated tire would not be a good idea on a disco, for that matter just FYI a service load index of 109 (2271) or D rated and greater should be used on the disco. imo.
J
began
11-23-2008 08:59 AM
