Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
How much to deflate for Sand / Rocks?
Old Oct 23, 2009 | 03:54 PM
sn1987's Avatar
Default How much to deflate for Sand / Rocks?
What pressure would you use for deep sand and what for rocks and sharp stones without risking too much of getting the tire lose on wheel?
I drive now 255/70/16"
Thanks!
Old Oct 23, 2009 | 05:53 PM
hilltoppersx's Avatar
i say 17-20psi depending how soft the sand is
Old Oct 24, 2009 | 07:41 AM
jayv's Avatar
I have been driving on sand and rocks for 30 years. on sand 15 PSI. on rocks, depends on your tire wheel set up. if you have a c rated tire i would stay at 20 pounds no lower becasue of the weight of the LR. if you run a E tire you could go as low as 15, if you run a E tire with bead locks you could go as low 5 psi depending on the level of rocks you are running.
the point is, sand is easy, 15 PSI, rocks takes more thought.
Old Oct 24, 2009 | 08:24 AM
sn1987's Avatar
thank You, it helps!
Old Oct 24, 2009 | 08:48 AM
Jay, I noticed that you mentioned a "C" rated tire and wasn't sure if that is what you are running. if so, for what it is worth, because of the Rovers weight and top heavyness, a "C" rated tire can't not be run safely. "D" and "E" rated tire are required for the stronger side wall.
As for what I run when wheeling, no mater if it is on sand or extreme rocks, I run 18#'s with 8" wide factory wheels and 265/75/16's, anything less then that and I tend to roll my left front tire bead.
Old Oct 24, 2009 | 10:28 AM
jayv's Avatar
Even on an E rated tire, you roll the bead? wow. i wouldnt have expected that.
I agree wiyth you 100% yuor 18 PSI is a nice one to run, i think once you get into the 35" tire range though you may find the volume of air at 18 is a little to stiff. but no matter.
yes, a c rated tire would not be a good idea on a disco, for that matter just FYI a service load index of 109 (2271) or D rated and greater should be used on the disco. imo.
J
Old Oct 24, 2009 | 11:00 AM
sn1987's Avatar
i have cooper discoverer S/T, how are they rated?
Old Oct 26, 2009 | 09:25 AM
Not sure what rating you are looking for. Most information is stamped on the sidewall of the tire. If you are looking for what air pressure to run, that will depend on your tire size, what size are your tires?
Alex_M
Sep 17, 2014 06:24 PM
Chris on Maui
Nov 21, 2009 04:33 PM
began
Nov 23, 2008 08:59 AM
Kraftyz51
Oct 21, 2007 10:25 AM
tap121
Apr 10, 2007 07:35 PM
