Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
head unit
Old Aug 16, 2010 | 07:53 PM
maitai's Avatar
Default head unit
is there a wireing harness addapter i can buy to put an aftermarket head unit in my 02 disco
Old Aug 16, 2010 | 08:36 PM
Rover Chris's Avatar
metra part number 70-1786
Old Aug 18, 2010 | 09:39 PM
maitai's Avatar
thanks alot ill give it a try
Old Aug 20, 2010 | 10:22 AM
Silver_Slug's Avatar
it makes life a thousand times easier. took me five seconds to wire my new radio. (+- a few mins for crimping)
Old Aug 21, 2010 | 08:32 PM
bentonrover's Avatar
Dont mean to hi-jack but same question for a 99 range? Also where can I get it from. Thanks
Old Aug 21, 2010 | 11:03 PM
should be the same harness, if you buy things online either google 70-1786 or ebay it. otherwise crutchfield or your local car audio shop (go to a private shop and not a best buy type store) if they don't have it just give them the part number and they can order it for you. by the way that is a metra part number, and there are other harness's for these trucks so use that number not just the truck info.
Old Aug 30, 2010 | 07:39 PM
Hook the head unit up no problem. Now where's the antenna wire at lol..do you the part # for that. Thanks
Old Sep 1, 2010 | 05:55 AM
any car audio shop, ask for a non amplified European antenna adapter. metra lists it as a VW adapter 40-VW12 there are 2 you will use the "main" one.
98roverguy
Oct 13, 2006 04:48 PM
BlueDisco
Aug 21, 2006 11:44 PM
2k2wranglerx
Mar 22, 2006 04:55 PM
beavis4g63t
Mar 14, 2006 02:55 PM
brunettc
Aug 8, 2005 07:31 AM
