Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
help needed
Old Jun 28, 2010 | 02:34 PM
cheese's Avatar
3rd Gear
Default help needed
Hi All,
I am fitting a sub and amp into my 2000 discovery. I have run a new power cable and found a good ground. I have run a remote and RCA cables off my replacment pioneer head unit. Everything seems good and there is a good 13+ volts reading a the amp (engine running) but when I turn the head unit on, the voltage drops to 5v and the amp won't turn. Thinking it was the amp, I replaced the amp with a brand new one, but the same thing happens.
Does anyone have any ideas???
thanks
John
Old Jun 29, 2010 | 09:30 AM
tnhotrod's Avatar
Default amp problem
check the wire you have the remote hooked to with a meter on the back side of the radio . You might have it hooked up to the power antenna output..
mandythelandy
Engine & Internal
Apr 9, 2008 01:15 PM
DiscoPete
Sep 29, 2006 03:22 PM
masher
Dec 31, 2005 09:56 AM
redmel
Nov 14, 2005 09:03 AM
asmcmillin
Apr 4, 2005 02:04 PM
