Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
oem door speaker size?
Old 11-16-2013, 05:08 PM
me 2's Avatar
Default oem door speaker size?
Hey guys, looking to replace the front/rear door speakers as well as the rear door woofers. What size are these speakers? Thanks
Old 03-05-2014, 08:40 PM
GGhost's Avatar
6.5" for all four door bottoms and rear two. Top of front doors are 2.5" but with door panels off it is quite easy to enlarge them since it is essentially foam board. Mark on the inside and use a razor tool to cut. Just added 4" 's to the door tops and will be changing out the bottom set. The 2nd row bottoms do have grills that have about 6 wedge snaps holding them on. On my 2004 the front door panels DO have to come off to expose speaker mounts. The A pillars hold a 1.5 tweet. The "speakers" on the 2nd row top don't look even like speakers, not even sure what they are. They are branded HAES and are the only ones with an 8 Ohm marking. All others are 4 Ohm. 15 watt(s) on low and mid systems and 30 watt on the HK or "hi-line"
FLA Rover (04-18-2015)
Old 05-12-2014, 05:21 PM
The_OGCJR's Avatar
maybe those are some kinda of noise cancellation ****? On the 2nd row tops I mean
JohnKimble
10-28-2013 06:13 PM
kkudwoli
Sights N Sounds
04-22-2009 04:09 AM
sowr
02-13-2009 05:55 PM
theworks001
09-28-2008 12:59 PM
sdsilvere38
09-14-2008 07:50 PM
Quick Reply: oem door speaker size?
