Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
using cargo door speaker wires for 10" sub?
Old 06-02-2014, 02:37 PM
aftermath431's Avatar
Default using cargo door speaker wires for 10" sub?
I have a 2000 disco II. I'm wanting to remove the two speakers in the cargo door and use the wires that where going to them to hook up one 10" sub woofer. Can I use the positive and negative wires that went to one of the cargo door speakers and just connect them to a sub woofer since i'm removing the two speakers anyways?
Old 06-04-2014, 07:13 AM
Default help with adding a 10" sub woofer?
Originally Posted by aftermath431
I have a 2000 disco II. I'm wanting to remove the two speakers in the cargo door and use the wires that where going to them to hook up one 10" sub woofer. I will only be using the stock HARMAN KARDON AMPLIFIER and thinking I don't have tyo do anything since it should already be connected. My question is can I use the positive and negative wires that went to one of the cargo door speakers and just connect them to a sub woofer since i'm removing the two speakers from the cargo door anyways?
I would appreciate any help.
Old 06-04-2014, 09:18 AM
04duxlr's Avatar
It will work. The OEM wiring is pretty light gauge stuff but if you are using the stock amp it isn't an issue. You will likely be less than thrilled with how that setup will sound though because the stock amp isn't very powerful. Nothing you can't fix after the fact though!
Old 06-05-2014, 01:07 AM
Thanks for the help I appreciative it.
Old 09-10-2014, 09:36 PM
cybercop's Avatar
If you did this, I would get a dual voice coil 10 and hook up both pairs. You would have to fab a box.
I would think you would definitely need a amp with better wire running to them.
jycsalas
05-23-2019 03:02 PM
nicke
11-01-2012 12:34 PM
TenMan1
05-07-2012 02:22 PM
4x4ron
02-12-2012 10:52 AM
VikingDiesel
10-25-2009 09:33 PM
Quick Reply: using cargo door speaker wires for 10" sub?
