Defender Talk about the Land Rover Defender within.
300Tdi water pump housing hole WTF !!
Old Oct 2, 2010 | 08:24 PM
AussieDefender's Avatar
Default 300Tdi water pump housing hole WTF !!
I have just taken off the water pump pulley to see where the water leak was coming from only to discover a hole in the top front of the water pump housing.
It's a perfect hole with no thread. Water is leaking out of here.
Any ideas?
Cheers
Barry
Old Oct 2, 2010 | 10:57 PM
lordmorpheus's Avatar
Most, if not all, water pumps have a weep hole to allow lubrication from the bearing to escape the pump without going into the coolant. If coolant is leaking from that hold, the internal seals of the pump have failed and a new pump needed.
Old Oct 3, 2010 | 02:54 AM
I stripped it off and though it was a seep hole as there was another underneath.
Oh well there goes another $100
Cheers
Barry
Old Oct 4, 2010 | 03:10 AM
giggs6989's Avatar
3rd Gear
$100 for it?so expensive
Helper
Dec 14, 2010 08:18 PM
audiS4S6
May 6, 2010 12:14 PM
lipadj46
Jul 9, 2009 04:03 PM
Pwn777
Jun 14, 2009 07:48 AM
panther9
Aug 7, 2008 08:41 AM
