Leaking Machined hole in water pump?
Old Aug 7, 2008 | 08:18 AM
panther9's Avatar
5th Gear
Default Leaking Machined hole in water pump?
Goodmorning,
1998 Disco I.
Noticed a severe coolant leak yesterday. Identified the leak as coming from a (machined) 1/8 to 1/4 in hole on the battery side of WP? Other than this hole leaking coolant the pump is not leaking at the gasket or anywhere else and is pumping fine?
Question... what was in this hole, can it be closed back off? It seems that if I can replug this hole that will solve the problem without replacing the WP.... is this possible?
Thank you,
Matt milligan
Old Aug 7, 2008 | 08:24 AM
Landzu's Avatar
Default RE: Leaking Machined hole in water pump?
The hole that you are talking about is a weep hole it is there to let you know that the inner seal has failed on the water pump and the water pump need to be replaced.
Old Aug 7, 2008 | 08:41 AM
panther9's Avatar
5th Gear
Landzu,
That answers my question... thank you very much.
TRIARII
Oct 21, 2014 12:08 PM
LADEROUTE
May 16, 2014 12:17 AM
Helper
Dec 14, 2010 08:18 PM
audiS4S6
May 6, 2010 12:14 PM
RRWHEELS
Feb 5, 2009 10:12 PM
