Defender Talk about the Land Rover Defender within.
TD5 oil pan removal
Old Sep 5, 2019 | 06:49 AM
intlclarke's Avatar
Default TD5 oil pan removal
hi, all. Im new to the form. I'm trying to drop the oil sump on my TD5. There doesn't seem to be enough clearance. ( the defender is on axle stands). Should I jack the defender a different way to create a bigger space between the front axle and pan? ( i'm doing this to replace the oil pocket bolt). Any suggestions are appreciated.
Old Sep 6, 2019 | 07:03 AM
The Deputy's Avatar
Yes, try and support the body by the frame rails. You can leave the vehicle on the jack stands, just lift it by frame rails slightly, then add jack stands under frame rail, you should gain enough room to remove pan.
Brian.
Old Sep 6, 2019 | 01:23 PM
intlclarke's Avatar
thank you Brian
Bryan H
Oct 8, 2010 12:06 AM
jm12503
Aug 24, 2010 11:30 AM
Rover Curious
Jan 26, 2009 04:19 PM
chargersfan
Aug 25, 2007 12:22 PM
jconway
Jun 20, 2005 03:21 PM
