Oil Pan Removal Question
Old Oct 5, 2010 | 09:11 PM
Bryan H's Avatar
Default Oil Pan Removal Question
Can the pan be dropped without removing the front cross member? 6 out of the 8 bolts are totally rusted in (yes, I've used PB Blaster) and the heads are rounded. Just looking at it, it seems like you could let the front axle droop and have plenty of room to get the pan out.
Old Oct 7, 2010 | 01:13 PM
Bryan H's Avatar
Anyone?
Old Oct 7, 2010 | 03:58 PM
Long Haul's Avatar
I know on a D1 you can put a jack between the axle and the frame enough to get the pan out. Im not 100% sure on the D2.
Old Oct 7, 2010 | 09:37 PM
lordmorpheus's Avatar
According to Rave, Yes you can remove it without taking out the cross member.
Old Oct 7, 2010 | 11:02 PM
Bryan H's Avatar
Really? Rave says remove it as far as I can tell. Where are you seeing it otherwise? That's great if that's the case.
Old Oct 8, 2010 | 12:06 AM
Geez. I don't know what I was drinking tonight, but I stupidly glossed right over that heading, and picture of the cross member while checking.
Just under the picture of the cross member showing the 8 bolts:
6. Remove 8 bolts securing cross member and remove cross member.
*wishes I could find an emoticon looking stupid and slapping itself in the forehead*
mike111
Jun 2, 2014 08:58 AM
Dan7
Feb 26, 2014 09:06 PM
MrFlea1
Dec 22, 2011 04:31 PM
lipadj46
Nov 17, 2009 11:13 AM
91rover
Jul 27, 2007 05:04 AM
