Defender Talk about the Land Rover Defender within.
what does it indicate?
Old Feb 19, 2008 | 03:35 PM
def90rich's Avatar
3rd Gear
Default what does it indicate?
hi on my def90 200tdi i have come accross a warning light i have never seen before.. a cog with a thermom inside it? bear in mind it was frosty this morn and it stoped me from starting it even after glo plug light went off.. my manaul say's nowt and just want to know what it does
Old Feb 19, 2008 | 05:21 PM
Default RE: what does it indicate?
On my Disco 2, that would be a tranny over heat light, do you have a stick or automatic? You may find it is also being caused by a short or bad switch.
Old Feb 20, 2008 | 12:29 AM
def90rich's Avatar
3rd Gear
shes a uk 5 speed manual, and it was me starting it first thing in the morning and it was below minus 3 centingrade...
Old Feb 20, 2008 | 08:22 AM
Adz's Avatar
Adz
Hi Rich,
Where on the instrument panel did you find it? Can't see it on mine...
Old Feb 20, 2008 | 12:29 PM
def90rich's Avatar
3rd Gear
adz,
Turn you ignition key till your dash lights up and once the glo plug goes out look out for a red light with the said description under your indicator light and turn her over and it comes on for a second, well mine the other morning came on and locked out the starter.... try'd a few times and then it went off.. its like a gearbox oil light but she had just come back from a long slog on the M6 (1236miles) and this was the following morning of this week end trip.. confused to what it is and why lock out the starter when all level's where correct and saying that the starter will operate up to minus 25..
Old Feb 21, 2008 | 01:22 PM
Adz's Avatar
Adz
Nope... it's not there on my instrument panel... got a digi camera? Post us a pic if you can.
Cheers,
ljdiscovery
Jul 29, 2009 09:30 AM
ScottJ
Oct 2, 2007 02:19 PM
TahoeDoberman
Aug 21, 2005 02:40 AM
Evian
Aug 18, 2005 11:34 PM
flyingcouch
Jan 22, 2005 08:25 AM
