Too many D1's
Old 06-28-2014, 07:39 AM
TOM R's Avatar
Yeah cruise is on my list, did this d2 module and it worked as long as I held the button then stopped all together again, new hoses good vacume diaphragm, brake pedal switch and several pumps that tested good, no go
  #22
Old 06-30-2014, 06:11 PM
fishEH's Avatar
Pulled the rear seats and carpeting out tonight. When you get right down to it there's not a whole lot to these trucks.
Look at all that room!!!
  #23
Old 07-11-2014, 06:44 AM
96 rover's Avatar
Do you still want the maf I sent you a pm
  #24
Old 07-11-2014, 06:57 AM
fishEH's Avatar
Yes! Sorry somehow I missed that PM.
  #25
Old 07-14-2014, 07:57 PM
fishEH's Avatar
Pulled out the TC neutral safety switch and the ghetto fab bypass switch the PO installed.
Got the Vehicle Speed Sensor 95% removed before I had to stop to go out for dinner. Will probably swap in the rebuilt one tomorrow as well as swap starters.
  #26
Old 07-15-2014, 08:17 AM
96 rover's Avatar
Maf going out tomorrow
  #27
Old 07-15-2014, 08:23 AM
MM3846's Avatar
lol that thing is pretty ghetto
  #28
Old 07-21-2014, 06:23 PM
fishEH's Avatar
Default Ah Ha!!!!
So after I yanked the TC neutral solenoid the stupid truck wouldn't start. Not start as in not even crank. I tried a variety of things but kid's birthdays and a promotion at work and such have kept me busy. Finally did a little research and it turns out the Alarm Module gets a ground through the very solenoid I removed. I stuck a vampire clip onto the wire from Pin 1 on the smaller white plug and touched it to a bolt inside the cab. Turned the key and it fired right up!
Man that's a satisfying feeling.
Now onto more fun stuff like cutting and welding floors.
  #29
Old 07-21-2014, 06:40 PM
HammerFit's Avatar
After seeing this pic, I'm taking my back seats out. I use this as a truck anyway.
  #30
Old 07-21-2014, 06:48 PM
HammerFit's Avatar
whats behind this thing?
Quick Reply: Too many D1's
