Water pump Gasket Sealer Question
Old Dec 26, 2011 | 12:25 PM
Travelor's Avatar
Default Water pump Gasket Sealer Question
Hi Guys,
Going to be removing a bad water and installing a new pump today -
The question:
Do I need to use a gasket sealer along with the gasket that came with the new pump?
Always appreciate any and all input..
Trav...
Old Dec 26, 2011 | 09:00 PM
I used a very light application with mine. See atached page from RAVE, in typical Roverspeak, it is called a "joint washer", see #5 on drawing.
File Type: pdf
Old Dec 26, 2011 | 09:05 PM
Danny Lee 97 Disco's Avatar
Isn't that a gasket? So did you just apply sealant with no gasket?
Old Dec 26, 2011 | 09:41 PM
Travelor's Avatar
That is why I am asking - I read the RAVE before - the same section - It doesn't mention anything about using a sealer.. and the gasket I have is paper - oil wouldn't work - in my mind at least..
Trav...
Old Dec 27, 2011 | 09:08 AM
Thin RTV or Hylomar (spray if you can find it). You are holding the gasket in position on a vertical surface for assembly, and it is paper thin (oil just holds it). Can also be done with Oklahoma grade full strength RTV if no gasket around, but gasket is the best way.
Old Dec 27, 2011 | 11:03 AM
wheelgarage's Avatar
I always use a thin layer of ATV, black or grey...
In regards to Hylomar, I recall when that stuff came out. Not too sure if the formulation has changed, but I never had success using it when I rebuilt a few rotary engines, always had issues with curing. The new ATV's and the good'ole Permatex sealant will always do the job....
Old Dec 28, 2011 | 05:56 PM
sideburns's Avatar
I would use the gasket only, no sealer.
Old Dec 29, 2011 | 12:10 AM
Jake1996D1's Avatar
Same! I didnt use any on my last one IIRC just a little bit of grease to get the gasket tacky enough to stay in place while mounting the new pump. They also sell those single shot t-stat and water pumper sealant packets at most auto parts stores if you go that route.
Old Dec 29, 2011 | 03:39 PM
Chris-bob's Avatar
I used RTV applied thinly with an acid brush when I did my water pump a few months back. Just enough to cover the gasket on both sides.
lmcgrew79
Dec 10, 2020 06:52 PM
tylor36
Oct 2, 2013 02:26 PM
Externet
Sep 7, 2012 09:32 AM
downeast207
Jun 25, 2012 05:41 PM
