Advice on running wire from dash to engine compartment?
Old 10-19-2016, 03:19 PM
bigbalu's Avatar
Default Advice on running wire from dash to engine compartment?
Looking for advice on the easiest routing of a single wire from on top of the dash to the engine compartment.
Need to run a wire from a dash-mounted solar panel to the battery (to trickle charge).
Plan A is to go across the dash to the passenger side, down to glove box or fuses on that side in the footwell, and find whatever hole that wiring comes through.
But welcome any tips to avoid problems.
98 Disco I.
Old 10-19-2016, 06:28 PM
fishEH's Avatar
Drivers side, below the brake booster. There's a grommet there with a bunch of wires going through it and its easy to get to. Should be real easy to run multiple new wires through it if needed.
The following 2 users liked this post by fishEH:
keoni004 (10-19-2016), mr4x4 (10-22-2016)
Old 10-20-2016, 11:57 AM
bigbalu's Avatar
Thx. Will look for that.
ngarover
12-05-2010 08:54 AM
RoverRover1
06-01-2009 09:37 AM
luxury1
04-26-2009 08:39 PM
dalfier
06-13-2007 09:51 PM
bigugly82
12-31-2006 03:13 AM
Quick Reply: Advice on running wire from dash to engine compartment?
