Advice on running wire from dash to engine compartment?
Old Oct 19, 2016 | 03:19 PM
bigbalu's Avatar
Default Advice on running wire from dash to engine compartment?
Looking for advice on the easiest routing of a single wire from on top of the dash to the engine compartment.
Need to run a wire from a dash-mounted solar panel to the battery (to trickle charge).
Plan A is to go across the dash to the passenger side, down to glove box or fuses on that side in the footwell, and find whatever hole that wiring comes through.
But welcome any tips to avoid problems.
98 Disco I.
Old Oct 19, 2016 | 06:28 PM
fishEH's Avatar
Drivers side, below the brake booster. There's a grommet there with a bunch of wires going through it and its easy to get to. Should be real easy to run multiple new wires through it if needed.
Old Oct 20, 2016 | 11:57 AM
bigbalu's Avatar
Thx. Will look for that.
ngarover
Dec 5, 2010 08:54 AM
RoverRover1
Jun 1, 2009 09:37 AM
luxury1
Apr 26, 2009 08:39 PM
dalfier
Jun 13, 2007 09:51 PM
bigugly82
Dec 31, 2006 03:13 AM
