made a gas tank skid today
Old Feb 1, 2012 | 08:21 AM
blackandtandisco's Avatar
Default made a gas tank skid today
I was under the truck this morning looking for an intermittent rub/chirping/squeeling sound. Thought it might be a stuck caliper but now I think it could be something in the parking brake drum. While under there I found the gas tank skid had broken in half. So instead of looking for a $20 replacement or a $160 all aluminum replacement, i decided to make my own.
Found some scrap steel, 1/8 inch electrical panel door should work.
I wish it was a bit wider. Now i need a brake... grabbed some more scrap and welded hinges
The brake needs work... i think i had it upside down, it worked ok, but definatley needs to thought over. With a little bit if work i was able to make this
I was off about an inch, so i had to bolt one side up and kind of squeeze the skid so it would line up with the other holes. I broke 3 of the original skid bolts and 2 sway bar bolts. Got it together and driveable, i will have to take it down to paint it and install some grade 8 hardware instead of the "any-size just to get it on the road" bolts that it has now. im also thinking of welding a little extra protection on either side to fully prtect the tank. 1/8 inch seems pretty good, not sure how hard of a hit it will take but i dont think it will collapse and i know the tank wont fall out while driving.
Attachment 8122
Attachment 8123
Old Feb 1, 2012 | 10:14 AM
Old Feb 1, 2012 | 11:32 AM
EricTyrrell's Avatar
Looks much better than before. That was some bad rust.
Old Feb 1, 2012 | 11:57 AM
fishEH's Avatar
Not bad for free. 1/8" is a little thin to act as a "skid" but it should offer enough protection to prevent your tank from getting puctured. And anything was better than that old strap, man that thing was rusted.
Nice work!
badfysh
May 16, 2015 07:29 PM
dusty1
Aug 18, 2014 10:18 AM
aarongregor
Nov 21, 2012 04:08 PM
Fivespddisco
Dec 22, 2011 09:29 AM
Jake1996D1
Jun 6, 2011 06:35 PM
