Brake recommendations
I installed a set of EBC pads on mine from Roverparts a couple years ago. They seem to be wearing well, don't seem to fade too badly, don't produce an excess amount of brake dust, however, they do tend to squeal fairly often when they first make contact with the rotor upon braking (but typically not during the entire braking process). Part of that reason is probably due to the funky trapezoidal shape of the brake pad/caliper design ...and the way the pads are designed to fit into the caliper. I've actually had a pad (a long time ago) shake loose and dislodge itself from it's seat in the caliper and grid it's way deep into a rotor. Never had that happen on any other vehicle before. But those weren't EBC pads ..and more the fault of the overall design. I do like about these pads that they don't seem to be as sooty, and what soot is produced, washes off pretty easily with soapy water.
bcolins
10-07-2015 12:25 PM
sparky
04-13-2008 09:13 AM
